I first ran into this problem months ago. The check gages light came on and the battery gage needle went all the way to the left. I thought, "It's starting and running fine, so it's probably fine." Down the road the belt started squealing. So, I replaced the belt, and it still showed the check gauges and dead battery but ran fine for a while. Further down the road, the lights in the truck started flickering on and off on the dash randomly and when I got home the truck was completely dead. I figured; it's got to be the alternator. So, I replaced it, and it still had the same problem. So, I thought, it's got to be the battery. Replaced it. Same problem. I then cleaned off all the ground wires. Same problem. So, I replaced the fuse relay (TIPM). Same problem. Replaced the tensioner pully. Same problem. I'm at a complete loss. What else could possibly be the problem?
Feb 1, 2025 at 4:03 PM
