The interior light was left on and the battery completely drained, I charged the battery and the car started. However, Audio alert shows up and radio does not work. Fuses are good. I went online and they suggested disconnecting the neg battery terminal and reconnecting to see if that works which I have not tried yet. If not disconnect both terminals hit the brake pedal to drain power(?) and touch the neg and pos cables together. Is the safe or what do you suggest?
Thank you,
Don Hoder
Thank you,
Don Hoder
Dec 6, 2022 at 8:12 AM
