Battery warning light turning on?
2005 MERCEDES BENZ C200
350,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
ABOOTHMAN
  • 8 POSTS
Hi dear,
I had battery alternator warning light, and it was voltage regulator problem. I couldn’t find one, so I bought a new alternator. Two weeks after installing the new one the warning light comes on for seconds and sometime for minutes and goes off. It does it three or four times daily.
I hope I was clear thank you.
Oct 27, 2023 at 4:34 PM
Yep, it sounds like you have a defective alternator. Can I ask which brand it is? To help confirm the issue of when the warning light is on let's use a voltmeter is see if it charging or not?
This guide can help:
Here is the correct way to replace the alternator in case you need it. Check out the images (below). Please let us know how it goes.
Oct 27, 2023 at 5:10 PM
ABOOTHMAN
  • 8 POSTS
Hi there, thanks for replying. The alternator brand is Bosch. I’ll measure the voltage when the light comes on and tell you.
Thanks
Oct 29, 2023 at 11:37 AM
ABOOTHMAN
  • 8 POSTS
Hi dear,
Thank you very much.
I was waiting for the warning light to go on but it goes off straightaway so I couldn’t measure the voltage when the warning light is on. But I found the cause of the problem was the lower coolant hose which is above the alternator was leaking and dripping on the alternator causing the light to goes on and off. Fixed the leak and the problem has gone.
Nov 5, 2023 at 1:32 AM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Nov 5, 2023 at 11:42 AM
