I have removed three bolts and don't see anything else holding it in, but it will not budge.
Mar 19, 2022 at 12:31 PM
SQM
CERTIFIED EXPERT
These trays usually have a pin on the underside, which pushes into a rubber grommet. You should be able to pull firmly to release that.
You might have to move it back and forth before pulling on it.
Let me know if you have any questions.
Thank you.
Mar 19, 2022 at 10:20 PM
CLAYTON MERRICK
MEMBER
I'll give it a look over later this morning. thank you
Mar 20, 2022 at 3:27 AM
SQM
CERTIFIED EXPERT
You are welcome. Let me know how it goes.
Mar 20, 2022 at 8:49 AM
CERTIFIED EXPERT
Make sure to check the under side bracing which can hold the tray into the car.
