Battery touching hood the positive terminal and came in contact with the hood and burned a whole through it?
1999 PEUGEOT 306
70,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
KAPTEN FRISK
  • 23 POSTS
I was out drifting a couple days ago and went over a bump. I had forgotten to tighten the battery down a couple days before, so the positive terminal came in contact with the hood and burned a whole through it. No matter how i twist or turn the battery now it's still in contact with the hood. Right now, there are a couple layers of duct tape isolating the hood, but would some duct tape be enough or do I need to get some real isolation or a smaller battery?
Dec 15, 2024 at 6:14 AM
Yes, you called it, they make shorter batteries which will solve the issue, so I would remove the old battery that is too tall and install the shorter battery. If you go to the auto parts store you can use a tape measure to get the correct dimensions that will work. Let us know if you need anything else.
Dec 15, 2024 at 4:11 PM
KAPTEN FRISK
  • 23 POSTS
So just insolation won't work?
Dec 16, 2024 at 12:26 AM
It will for a while but it will rub through, the safe route is a shorter battery.
Dec 17, 2024 at 10:00 AM
KAPTEN FRISK
  • 23 POSTS
Alright, thanks.
Dec 17, 2024 at 10:21 AM
You are welcome, please use 2CarPros anytime we are here to help.
Dec 17, 2024 at 10:27 AM
