Not crank no start after replacing the battery?
2002 TOYOTA TACOMA
145,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
TINA MATHEWS
Won't start after replacing battery. Won't turn over. Headlights work. Door ajar chime works. Dome light doesn't work. Nothing on the dash lights up.
Jul 25, 2022 at 1:02 PM
I assume it worked before the battery was changed. If so, it sounds like the battery cable has a bad connection. Here is a guide that can help you fix it:
Jul 25, 2022 at 5:34 PM
