Battery replaced but drains
2008 LEXUS ES 350
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEANNE PARRISH
  • 9 POSTS
Hello. having recurring problem car was not starting, just clicking (started two years ago, December and bitter cold). replaced battery with upgraded battery. when weather got warm into spring summer fall no problem. last winter same problem. had replacement battery put in under warranty. no more problems. now it is December again and cold. but not bitter. same problem three times in last few weeks. paid service station $50.00 to check it and recharge it to 100%. then same thing again; clicking but wouldn't start. had it jumped again by road service two or three days ago. today same problem. only takes a couple days for this to happen. making sure courtesy lights off, radio off, heating system off, device charging cords unplugged.
Dec 18, 2018 at 7:45 AM
Good afternoon,
It sounds like you have a parasitic drain from the battery. in other words, something in the car is draining the battery power quicker than it should.
https://www.2carpros.com/articles/car-battery-dead-overnight
did the shop do a parasitic drain test?
Dec 18, 2018 at 10:43 AM
JEANNE PARRISH
  • 9 POSTS
I don't think so. I just discovered that term today as I was searching for information.
Dec 18, 2018 at 12:56 PM
JEANNE PARRISH
  • 9 POSTS
How would that test be done, what steps? By the way, thanks for answering so quickly.
Dec 18, 2018 at 12:58 PM
JEANNE PARRISH
  • 9 POSTS
Ha! I just went to the site you cited above and I had already read it.
Dec 18, 2018 at 1:03 PM
JEANNE PARRISH
  • 9 POSTS
Meaning I have already read the steps.
Okay, do this procedure.
Remove the negative cable and get a voltmeter. put the red lead on the battery terminal and the black lead on the negative cable.
set the meter to DC amps and let the car sit thirty minutes for the modules to go to sleep.
Then read the meter. you should have 50-75 milli amps as a draw. that is normal.
Dec 18, 2018 at 1:06 PM
JEANNE PARRISH
  • 9 POSTS
Roy, will do and let you know what happens.
Dec 18, 2018 at 8:26 PM
Sounds like a plan.
Dec 18, 2018 at 8:36 PM
JEANNE PARRISH
  • 9 POSTS
when it rains it pours.Waiting for replacement phone to come. they were fixing the cracked screen on site and it wouldn't work after it was put back together it isn't functioning. so no calls to mechanic; playing the waiting game. and so it goes, sometimes.
Dec 19, 2018 at 1:50 PM
I understand.
Keep us updated.
Dec 19, 2018 at 2:02 PM
JEANNE PARRISH
  • 9 POSTS
Hi Roy, believe it or not, my car was stolen along with my checkbook. car not yet recovered; forged check was written. Paricidic drain not yet been done. I will be in touch. Thanks.
Jeanne
Jan 4, 2019 at 11:59 AM
You are welcome.
Will be here to help when you need us.
Jan 4, 2019 at 12:02 PM
JEANNE PARRISH
  • 9 POSTS
Hi Roy. Car not recovered. It has been 30-days so insurance will consider it a total loss. Thanks for being there for everyone. You really know your auto advice. Best regards, Jeanne
Jan 30, 2019 at 10:00 AM
Thanks for the kind words.
We are always glad to help.
Jan 30, 2019 at 10:03 AM
