Normally, it is recommended to use what the vehicle came with. An AGM battery is designed a little differently which allows it to last longer, provide a more consistent power supply, and quicker charging, and is often used in vehicles that have a higher voltage need.
To answer your question, yes, you could use a traditional type. It will likely not last as long, but I don't see a concern with this vehicle.
Let me know if this helps.
Jan 16, 2024 at 6:10 PM
