My battery is overcharging when I turn on the car the gauge show battery overcharging. I checked the fuses, battery, generator, voltage regulator, the ground, and the wire running from the key switch to the voltage regulator all turn out ok and was looking at a video on YouTube that show you how to check your charging system and that overcharging can be caused by a field wire exposed to or a open contact with a A+ or battery wire in the harness can I bypass the harness where the wires are contacting each other and somehow connect the voltage regulator straight to the generator would that work.
Oct 23, 2023 at 4:15 PM
