Battery not charging
2002 GMC ENVOY
158,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
HAUCKELEGH
The Battery light is on. The car slowly shut off while I was driving home.
Mar 14, 2018 at 5:05 AM
Good morning.
Make sure the belt is turning the alternator.
The next step is to check the voltage at the back of the alternator. The most common failure is the alternator itself.
Do you have a voltmeter to do some checks?
Mar 14, 2018 at 5:09 AM
HAUCKELEGH
The belt will turn but it is very hard to make it move. Afraid I do not have a volt meter.
Mar 14, 2018 at 5:31 AM
Okay, can you get one? We need to check the voltage at the back of the alternator to verify its failure. you can rent one at a parts store.
Mar 14, 2018 at 5:34 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Very hard to make what move?
Mar 14, 2018 at 7:44 AM
HAUCKELEGH
Mar 14, 2018 at 12:02 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Are you trying to move the belt by hand?
If you have the key on run, the alternator will be live and difficult if not impossible to turn.
I think what asemaster meant was just to look at the belt while the engine was running and make sure the alternator is spinning.
Mar 14, 2018 at 3:17 PM
