The alternative in the picture is the correct one? did you post is picture? I do not see one? also the one that was replaced you had tested and it tested bad?
May 30, 2016 at 8:37 AM
SATURNTECH9
CERTIFIED EXPERT
Also do you have a internal or external voltage regulator?
May 30, 2016 at 8:43 AM
WILLIE BURKETT
MEMBER
Internal.
May 30, 2016 at 8:44 AM
WILLIE BURKETT
MEMBER
The picture was from another reply.
May 30, 2016 at 8:47 AM
SATURNTECH9
CERTIFIED EXPERT
Use a voltmeter and put the negative lead to the case of the alternator and the positive lead to the terminal a at the back of the alternator you should have battery voltage?
