That seems odd. This particular vehicle should typically set codes for charging system issues. Let's move on using a multi-meter and see if we can narrow down the issue. Take a look at the articles below to get started. The first discusses the use of a multi-meter if you're not already familiar. The second walking you through the process of testing the charging system. I've also attached a wiring diagram of the charging system for your reference.
Multi-meter instructions:
How to test an alternator:
Let me know what you come up with!
Nov 19, 2019 at 6:21 PM
