Battery light staying on?
2000 CHEVROLET SILVERADO
263,000 MILES • 4WD • AUTOMATIC
GRIFFIN8194
Security light flashing. When I start the truck the battery light stays on and the fuel gauge and odometer lights are not working. Passenger window isn't wanting to roll-up and the power door locks is barely working.
Jul 10, 2020 at 10:53 AM
Good afternoon,
The first thing I would do is check the battery voltage. It should be 12.6 volts.
https://www.2carpros.com/articles/how-a-car-battery-works
Then with it running, check the voltage at the battery again. It should be 14 to 14.6 volts.
Then change you voltmeter to read AC volts and tell me the reading. You may have a bad alternator causing all these issues.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Jul 10, 2020 at 11:06 AM
FOR SAL
2000 truck chevy, loosing ele, power all gauges go dead oil, radio, charging , battery lites go dim, after 3mins of driving everything to normal had battery and alternater checked good. tighten up cables .
Sep 3, 2020 at 6:26 PM (Merged)
Check the fuseable link between the alt and the battery. If it is bad, the alt can't get power to the battery. Also, check grounds. Make sure the battery terminals, ground to engine block, and all body grounds are clean, tight, and not rusted or corroded.
CONWAYMUSE
why wont my truck crank? it turns over and only the battery light will come on. -thank you
Does it crank over or it cranks over and refuses to start?
CONWAYMUSE
yes, it cranks but refuses to start.
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors-
LOPICCOLO49
Problem with Gauges!! They "dump" without warning and will eventually return.Oil,odometer,& battery will work.Cluster has been replaced 3 TIMES!! Battery icon appears in message center as gauges dump and stays on until they return. Any ideas? Tired of taking it back & forth. Need a good old fashion "wrencher" to help me out. Thanks-lopiccolo49
FIXITMR
  • 9,990 POSTS
gauge repair, now we know why it's a banking business? how long does the replaced gauge last?were they new, used , or repaired?
DCAMARO
  • 7 POSTS
I had the same problem! Turned out to be ground wires at the back of the L.H. head. you wont be able to see them, but reach in behind and you will feel two wires (black).These ground the dash cluster and they break off from vibration and being oil soaked.
Could be coming from the computer controlled of the alternator's field generation circuit-
JDL
  • 16,098 POSTS
Any applicable trouble codes? There are codes listed for the instrument cluster. The instrument cluster receives serial data from the pcm to operate gages. Any wrencher is the best at what make and model they work on the most, that's just how it is.
DEB991B
security and battery light stay on and flash this morning my dash gauges would not work
Sep 3, 2020 at 6:27 PM (Merged)
FIXITMR
  • 9,990 POSTS
if vehicle still functions and drives your instrument cluster needs repair. ebay has several low cost repair services.
JOE1953
  • 772 POSTS
my battry light is on and when i turn the headlights on they are dim but the engine is still cranking the battry voltage when the engine is running is below 12 voltage what is causing the battry light to be on when the engine is running?
CARADIODOC
  • 34,306 POSTS
The "Battery" light hasn't changed since the 1960s. It means the generator isn't recharging the battery while you're driving. What HAS changed is GM redesigned their generators for the '87 model year and it's a very poor design. They develop huge voltage spikes that can damage the internal diodes and voltage regulator, and can interfere with computer sensor signals. It is real common to go through four to six replacement generators in the life of the vehicle. To reduce the number of repeat failures, replace the battery at the same time unless it's less than about two years old. As they age, the lead flakes off the plates and they lose their ability to absorb those voltage spikes.
You already noticed the charging voltage is too low. Measured at the battery with the engine running, the voltage must be between 13.75 to 14.75 volts. If it is low, suspect the generator. If the voltage is okay, you need a professional load tester for the second part of the test. That will test for maximum output current and "ripple" voltage. If one of the six diodes has been damaged, you'll only be able to get exactly one third of the generator's rated maximum current, and ripple voltage will be very high.
JOE1953
  • 772 POSTS
I replace the alternater June 11th. 2013 I replace the battery June 12th. 2013. So I didn't replace both the same time.
JOE1953
  • 772 POSTS
I replace the alternater on today September 24 but I didn't replace the battery the engine is still cranking good, after I replace the alternater what do I do next drive the veichel?
CARADIODOC
  • 34,306 POSTS
You didn't list any symptoms now after the generator was replaced. The battery is likely still okay, so leave that alone for now. The old generator from 2013 worked okay for two years, so replacing the battery the next day was good enough to avoid another generator failure. The failure now was just "the nature of the beast". Every GM owner replaces their generator two or three times if they keep the vehicle long enough.
My recommendation now is to have the charging system professionally tested by a mechanic, not at an auto parts store. In particular, what I want to see is "regulation voltage" between 13.75 and 14.75 volts, full-load charging current very close to the generator's rated value, and "ripple voltage" should not be excessively high.
The common generators for your truck were a 105 amp, a 124 amp, and a 140 amp unit. Full-load current will be very close to one of those values, or, . . . if there's a defective diode inside the generator, you'll get exactly one third of that value. A generator is physically incapable of developing more current than it's designed for.
If ripple voltage is high, that is caused by the generator developing harmful voltage spikes, but it's the job of the battery to dampen and absorb them. Consider replacing the battery if ripple voltage is high/
SWENSON
  • 23 POSTS
i have a 1993 chevy k1500 silverado and just the other day i got in it and started it up and the battery light was on and the battery guage was almost all the way on the low mark. i just replaced the battery and alternator a couple weeks ago so i don't think it could be that. also when i start it up it idles at 2000 rpms when in park and 1500 rpms when in gear and i haven't changed anything this all just randomly happened. i cant fingure anyting out can anyone help me? i can't even listen to the radio when its running it just turns on and off. also a few months ago i realized that after i shut the truck off the windows still roll up and down without the key on
CARADIODOC
  • 34,306 POSTS
Beginning with the '87 models the GM generator is an extremely poor design. It is very common to go through four to six of them in the life of the vehicle. You already did what has been found to be most effective at reducing repeat failures. That is replacing the battery at the same time.
To verify if the new generator is defective, use an inexpensive digital voltmeter to measure battery voltage while the engine is running. It must be between 13.75 and 14.75 volts. If it is closer to 12.6 volts or less, double-check the voltage on the output stud on the back of the generator. On the rare chance it is higher there, look for a break in that fat wire that goes to the battery.
SWENSON
  • 23 POSTS
if the alternator was faulty wouldnt the battery be dead from not charging? and also do you have any idea about the idle problem
CARADIODOC
  • 34,306 POSTS
Not necessarily a dead battery. Since it's new it should be strong enough to run the fuel pump, head lights, and ignition system for a good hour or longer before it runs dead. I wouldn't be concerned about the idle speed just yet until the charging system is working. There's a number of computers on the truck that will do weird things when the system voltage is low. The same is true of the radio. You might be able to prove that by running the engine while a battery charger is connected and set on a low setting but keep in mind a working generator puts out a three phase output which is very steady with low ripple. A battery charger puts out a pulsing DC voltage that varies from 0 to about 18 volts 120 times per second. That too might affect some computers.
Another cause of high idle is a vacuum leak. GM has had a lot of trouble with leaking intake manifold gaskets but they usually leak coolant. Also, I think that became a problem after '93 models.
If something is not turning off with the ignition switch that allows the windows to still work, there should be other things on that circuit that also still work. That might include the radio, heater fan, or dash cluster.
SWENSON
  • 23 POSTS
ok so step by step what do you recommend i do to fix my problem.
NEWFIETREV
  • 5 POSTS
i changed the alternator and replaced the battery but the light stays on. What do you suggest?
Check wiring back to the charge light
https://www.2carpros.com/forum/automotive_pictures/12900_alty_45.jpg
CARADIODOC
  • 34,306 POSTS
If the voltage is lower than 13.75 volts at the battery and at the generator's output stud, it is either the belt is slipping severely, (doubtful), or the generator is defective. The only other thing that could be wrong is the "turn-on" circuit, but then the battery warning light would not work.
NEWFIETREV
  • 5 POSTS
thanks for the time wasted on my question. But i think i am going to sell it anyways. it has been giving me a headache ever since i bought it. first i had to put a new tranny in and then replace the steering column so now i think its time to get rid of it. thanks Trevor.
NEWFIETREV
  • 5 POSTS
Sorry about that i am very frustrated about my truck. it seems like every time i try to fix it something else goes wrong with it so if u have any other suggestions would you reply asap thanks again Trevor p.s. i found the problem, it had to deal with the instrument cluster on the fire wall to the right of the motor. i guess the guy who had the truck before must of burnt the wires and tried to duck tape them together. thank you again for your time.
https://www.2carpros.com/forum/automotive_pictures/327017_001_1.jpg
CDICKMAN
I just replaced a bad alternator on my truck, the battery was replaced in Nov. of '08. The auto parts store tested the new alternator before I left the store with it and it tested fine. The problem is after installing the new alternator the battery gauge still reads barely above 9 and the batter light is on. Is it possible for the battery to be bad already? or do I have other electrical problems. When the truck is off the battery reads 12 volts.
Get the battery load tested if okay and light continues to come on-check wiring if okay get the alternator retested.
BLEEZY123
Hi, I'm new to this site so I'm attempting to ask Caradiodoc a question. I was wondering if you knew whether or not the single wire plug on the alternator that you were talking about with another gentleman that had a problem with the wire that had the short in it. or could it be any of the wires having to do with the alternator charging? I read y'all's back and forth conversation and I tested mine by unplugging the wire and seeing if light stayed on in the dash. Mine stayed on. I've suspected a short was the problem but didn't know how to confirm it I hope you can make since out of my gibberish. Basically I just need to know if the short is going to be in that wire or is it possible it could be another wire other than it so i know where to focus my very little bit of patients I have toward the right thing. Thanks.
CARADIODOC
  • 34,306 POSTS
We should be able to figure this out. When there is only one small wire plugged in at the rear/side of the generator, current comes through the "gauges" fuse, to the instrument cluster, through the "battery" warning light, then goes through the brown wire at the generator. Roughly 10 volts is dropped across the light, so it turns on, and the 2 volts that is left at the generator is the signal for the internal voltage regulator to turn on and start doing its thing. Once the engine is running and the belt is spinning the generator's field winding, it produces its output current. The voltage regulator sees that, then it sends 12 volts back out on that brown wire. With 12 volts on that side of the light bulb, and 12 volts from the fuse on the other side, the difference is 0 volts, so the bulb turns off.
The first step in testing the system is to observe if the warning light turns on when the ignition switch is turned on. You did that. That proves everything is okay up to the bulb. Where things fell apart is when you unplugged the wire at the generator. That will break the circuit, current flow stops, and the bulb should turn off. The fact your bulb stayed on indicates current is still flowing through it, and to do that, it has to find a path back to ground, then to the battery's negative cable.
It sounds like you are describing an intermittent problem that only acts up at times. A confusing part of this system is the 2 volts on the brown wire tells the voltage regulator to turn on, but on these earlier systems, there is nothing to tell it to turn off. If the brown wire becomes grounded while you are driving, the warning light will turn on full brightness, but since the generator is up and running, it will continue to do so.
I should stop for a minute and explain the fundamental principle of "generating a current mechanically". Three things are required to do that. You need a piece of wire, a magnetic field, and most importantly, movement between them. Any time a magnetic field moves through a wire, it "induces" a voltage which causes current to want to flow. To make it much more efficient, we use many coils of wire for the wire, an easily-adjustable electromagnet to produce the magnetic field, and that is the part that spins thanks to the drive belt. That's the movement.
The voltage regulator controls how much current flows through the spinning field winding. It switches itself on when a couple of volts shows up on the brown wire, then, some of the generator's output current is used to keep the regulator powered up. As long as the engine keeps on spinning the generator, output current is produced, that keeps the voltage regulator powered up, and the regulator keeps the field winding powered up, and that keeps the generator producing output current, and on and on. There is no way designed in to let you switch that process off. The only thing that can stop it is turning the engine off. Once there is no movement between the spinning field winding and the stationary "stator" winding, output current ceases to be produced, and the system turns off.
I shared all of that magnificent story to point out the brown wire serves no purpose once the system is up and running as long as it is working properly. When an internal defect inside the generator develops, the voltage regulator stops putting 12 volts on the brown wire. There is still 12 volts on the fuse side of the warning light, but with no opposing voltage on the regulator side, the light turns on.
Ignition switch on/engine not running at this point. All of this light bulb operation works as designed when that brown wire is connected to the voltage regulator. The proof of that is the light turns off when you unplug the wire. Yours, however, does not go out. That means the brown wire has to be grounded someplace to the engine or an unpainted surface on the body sheet metal. If that short occurs before you start the engine, the voltage regulator will only see 0 volts on the brown wire, so it will not turn on. More on that in a moment. You'll see the "battery" light stays on, and system voltage is low. Lights will be dim and the heater and wiper motors will run slower than normal. If engine vibration makes that short go away, even for an instant, the normal 2 volts will appear on the brown wire, the voltage regulator will turn on, system voltage will rise to a normal 13.75 to 14.75 volts, and it will continue to work normally until you stop the engine, even if the short comes back and the warning light turns back on.
Now for the clinkers in my explanation. There are some variations in voltage regulators for some years and some applications. They used to turn on the warning light when the system stopped working, but now there are some that will turn the light on when an under-charge or an over-charge condition exists.
Next, all rotating field windings consist of a long wire wrapped around an iron core. It is common for that core to become magnetized over time. That "residual magnetism" can be strong enough to get the system started when there is a problem with the brown wire. We used to see this a lot with GM's much better 1986 and older system.
Finally, to diagnose this, the ignition switch must be off, and if this is an intermittent problem, it has to be acting up at the time you take the measurements. Unplug the brown wire, then use an ohm meter to test if that wire is indeed grounded. Here are links to some related articles:
The first article shows testing with an auto-ranging meter. If yours has a switch for selecting the range, use the lowest one for ohms, typically a 200 ohm range. If you need help with using the meter. let me know and I'll describe it for you. If that wire is grounded, it would normally measure 0 ohms, but be aware there is always a little resistance in the meter's leads, so expect to see around 2 to 5 ohms. You want to see an open circuit. Different meters have different ways of showing that. All you have to do is see what your meter shows when the probes are not connected to anything.
If you find a very low reading, prop the meter so you don't have to hold onto it, then work your way along the wire harness and flex or move it to see if the short goes away. You will rarely find the problem inside a straight length of "convoluted tubing" that is wrapped around the harness. The common places to find a grounded wire are where the harness is draped over the sharp edge of a metal bracket, or where it has fallen down onto hot engine parts. That brown wire runs behind the dash to the instrument cluster. The most common failure there is from someone adding accessories under the dash and they accidentally pinch a wire under a mounting bracket. The least common place to find this problem is in the "bulkhead" connector. That's the large plug on the firewall. Sometimes water drips down onto it and forms corrosion between adjacent terminals.
Now that I shared all that wondrous story, there is an even easier way you can approach this. Instead of using the ohm meter, have a helper watch the "battery" light while the ignition switch is on and the connector is unplugged at the generator. Your symptom is the light is still on. Now wiggle and move the harness around. The light will flicker off when you do something to make the short go away. That will tell you you're in the right area.
BLEEZY123
Thanks for the prompt response! I have to say that I'm blown away that you took enough time to give such detailed instructions and information. This morning before I was leaving I cranked the truck up hoping the light was on and I was in luck as it was. I went from the back of the alternator and followed the harness to the firewall wiggling and moving it around as I went. Checked the grounds that are visible and they were fine. So I go to get in truck and the light was off and after 50 or 60 miles of running errands and driving it never came on or did my voltage drop. I am going to see if I can locate the where it was grounding at and fix it properly. If I can't and it never gives me anymore problems then I'm okay with it remaining hidden. I owe all the thanks to you for helping that other guy out and giving me an idea of where and what to do. I suspected a short in a wire but didn't know if it would be at the back bumper or the radio and all in between. Saved me so much time and aggravation. I can't thank you enough.
CARADIODOC
  • 34,306 POSTS
I'll keep my fingers crossed.
