Battery light stay on untill reving car- 2001 Toyota Tazz km200 000
2001 TOYOTA TAZZ
200,000 MILES
WYNAND
  • 13 POSTS
Good day the Battery light on deskboard stay on untill reving car
I have tested the voltages regulator and alternator and that is working correctly
The battery light will stay on untill I rev the car hard and then the alatenator will start chaging the battery
I have check all the fuses - please advice
May 24, 2013 at 12:10 AM
HMAC300
  • 48,601 POSTS
check battery for condition and load test first.
May 24, 2013 at 6:43 AM
WYNAND
  • 13 POSTS
Good day the battery is a new and I also had this issue with the old battery
May 24, 2013 at 6:48 AM
HMAC300
  • 48,601 POSTS
then check the belt and tensioner, recommended replacement of belt and tensioner is 60,000 miles it may be slipping at low speed. make sure battery terminals are clean. we dont' have the tazz model in u.s. for that year but here is a corolla charging system diagram check the things I've pointed out in it. any of those could also cause a problem.
May 24, 2013 at 7:09 AM
