Okay,
First, they are parts salesman not technicians. That is why I keep asking for the results.
Do you have a voltmeter? I would like to see the actual readings to give you help and not guess which is what they did at the parts store at your expense.
There are only two connections on the alternator. The one for the big wire from the battery and the one connector. Make sure they are clean and tight.
Aug 24, 2018 at 6:54 PM
