I attached two pics below. They are the entire charging system for this vehicle. I highlighted two fuses I need to confirm you checked as well as a 175 amp fusible link.
On this vehicle, the fusible link looks like a regular wire but functions as a fuse. If it is burnt, you won't produce a charge.
To make this a little simpler, I need you to check for power at the alternator. The red wire containing the fusible link and the brown wire with a red tracer. Both should have battery voltage at the alternator.
Here is a link that you may find helpful:
Also, when checking the fuses, confirm there is power to and from them as well. The fuse may be good but there is no power available. Here is a link showing how that is done:
See pics below. Note: I had to cut the pic in half to make it readable. I did overlap them so you can follow from one to the next.
Jun 20, 2021 at 9:33 PM
