Battery light is staying on
2003 FORD FUSION
153,498 MILES • 1.6L • MANUAL
DAMIEN PARR
Had a new alternator put in yesterday and now the battery light is staying on. when we put the headlights on they go bright then dim, plus the air bag light has come on the dashboard.
Jun 13, 2017 at 12:07 AM
HMAC300
  • 48,601 POSTS
check battery for condition including load test most places do for free. make sure terminal ends are clean and no corrosion. then have belt professionally checked and tension-er, recommended replacement is 60,000 for both.
Jun 13, 2017 at 6:07 AM
STEVE W.
  • 15,113 POSTS
Check the "new" alternators connections and its output when all accessories are on. Also, double check that the correct alternator was installed.
Jun 13, 2017 at 7:58 PM
