Battery light
2005 CHEVROLET COLORADO
197,000 MILES • 5 CYL • 4WD • MANUAL
CAROLYNNEL2
  • 6 POSTS
I have an issue with the battery light. I replaced the battery and I replaced the alternator twice. also I changed the main fuse and it's still lit. what else should I check?
Jan 9, 2019 at 3:42 PM
Good evening,
You need to check the actual charge rate at the battery with the engine running. it should be 14 to 14.5 volts.
I will attach a wiring diagram for you to view as well.
do you have a voltmeter to do some wiring test? the PCM controls turning on and off the alternator system.
Jan 9, 2019 at 5:12 PM
CAROLYNNEL2
  • 6 POSTS
I have an issue with the gas tank sending unit because it fluctuates between full and empty. could that cause my issue too?
Jan 10, 2019 at 8:27 AM
No, that is a separate issue.
Jan 10, 2019 at 8:55 AM
CAROLYNNEL2
  • 6 POSTS
Okay.
Jan 10, 2019 at 12:17 PM
Let me know the results so we can continue.
Jan 10, 2019 at 12:24 PM
CAROLYNNEL2
  • 6 POSTS
Thank you, I definitely will.
Jan 10, 2019 at 12:38 PM
You are welcome.
Always glad to help.
Jan 10, 2019 at 12:40 PM
CAROLYNNEL2
  • 6 POSTS
The alternator was bad I replaced it twice. Third time's a charm thank you so much for your help.
Jan 11, 2019 at 2:52 PM
You're welcome.
Jan 11, 2019 at 3:15 PM
