Battery issues codes were from a low voltage?
2022 CHRYSLER PACIFICA
90,877 MILES • 3.6L • V6 • 2WD • AUTOMATIC
XVASQUEZ
The battery died due to a drastic change in temperature that we had and I plugged in my OBD2 sensor and it said all these codes were from a low voltage because the battery wasn't putting out enough power. I replaced the battery, put everything back to the way it was and it's still having issues. However, I did not replace the auxiliary battery. Should I go ahead and replace the auxiliary battery too to help with it? Or did just replacing the main battery work?
Feb 25, 2026 at 1:30 PM
STEVE W.
  • 15,113 POSTS
If the main went flat then you probably have a bad auxiliary batter as well. What are the codes you show?
Feb 25, 2026 at 7:02 PM
