Battery issue?
1992 CHRYSLER LE BARON
1,992 MILES • 3.0L • V6 • AUTOMATIC
HAKEEM1870
  • 9 POSTS
I got my battery tested and it read 400. At that time my car had been sitting for a couple of hours, then I drove to get it tested again and it read 900 which is better than what it’s supposed to be at which is 800 crank amps. what could be the issue?
Jul 3, 2023 at 4:01 PM
CARADIODOC
  • 34,306 POSTS
What is the issue? It sounds like they're using one of the new electronic testers. I'm familiar with the older style that loads the battery to simulate running the starter motor.
What kind of problem are you having?
Jul 3, 2023 at 5:08 PM
CARADIODOC
  • 34,306 POSTS
Sorry. I just saw your other post about the fuel issue. Since you have a fuel pressure gauge, run the hose under the back of the hood and clip the gauge under the wiper arm so you can see what happens to fuel pressure when the problem occurs. Also, tell me if that pressure drops to 0 PSI soon after you stop the engine, or if that pressure holds for a long time, as in many hours.
Jul 3, 2023 at 5:11 PM
HAKEEM1870
  • 9 POSTS
As for the battery I’m not sure exactly the problem.
I do have faulty wires in my car which turn on my flip headlights and my indoor light and my windshield wipers when I’ve already turned off the car. so, I’m assuming the battery is being drained by that, but I’m not sure if the starter or alternator have taken any damage because of that.
Jul 3, 2023 at 7:53 PM
CARADIODOC
  • 34,306 POSTS
Sounds like you have the GTS model. If I remember correctly, they used a relay box similar to those used on Daytonas. I'll have to research this, but for now, look under the dash, near or above the steering column, for a black box with about a dozen relays. I seem to recall those relays were not removable and if there was a problem, the entire box had to be replaced. Today I would pursue taking one apart to look for broken solder connections, but I wouldn't want to experiment with a customer's car. That brought back memories when you mentioned the hidden headlights. Two relays in that box were for that system.
Jul 4, 2023 at 2:39 PM
