Battery draining
1997 TOYOTA TACOMA
260,162 MILES • 3.4L • V6 • 4WD • MANUAL
TOYOTA4LIFE
  • 4 POSTS
Well first off my battery's keeps draining, I charged them then after a few days it would click then everything is dim or weak. it is not the alternator I tested it. then my starter acts like it was engaging slowly or hesitating to and a little grinding. I checked the connections the main starter wire is loose, I tried tightening it but it free spins. I thought it was that but if I jump it off it starts fine but will not start back unless jumped. I even put a new battery in it same thing acts weak with everything dims.
Jan 14, 2018 at 12:52 PM
KHLOW2008
  • 41,814 POSTS
I am a little confused about what you are trying to explain and hope I am getting it right.
When you installed a new battery, the problem immediately occurs means power is not getting to the starter or insufficient power is getting there. When dash lights are dim, it means either the battery is weak or connections are loose somewhere.
Jump a cable from the negative terminal of the battery to any part of the engine and test if there are any difference. If it resolves problem, check the ground cable from battery to the transmission/engine. It could be broken or connection is bad.
Jan 15, 2018 at 8:16 PM
TOYOTA4LIFE
  • 4 POSTS
Thank while doing that I noticed the positive wire to the start was loose its starting but there is a quick but rapid clicking from the starter relay
Jan 16, 2018 at 4:19 PM
KHLOW2008
  • 41,814 POSTS
If the starter wire is loose, it would result in the condition you described. You need to have the loose wire fixed.
Jan 16, 2018 at 9:48 PM
TOYOTA4LIFE
  • 4 POSTS
I did now I know if it does it again.
Jan 17, 2018 at 5:52 AM
It can be a seat switch causing a drain or a glove box light here is a guide to help you find the problem.
https://www.2carpros.com/articles/car-battery-dead-overnight
Jan 19, 2018 at 11:31 AM
