Having a consistent battery drain problem. It does not happen overnight or during operation, and the battery is able to take a charge. Interior gauge shows ~14v charging while running.
Battery is new enough to still be under warranty, and tested okay by auto shop.
If you leave the interior/aux power on while the vehicle is not running (such as by opening a door), it will drain the charged battery below the ability to crank the engine in under an hour. Maybe I'm wrong, but I don't think just the interior lighting would drain it that fast so I suspect something is contributing.
I've seen other posts here that mention checking for drain at specific relays and GEMS. If anyone has any likely suspects and could provide some details on what/how to test, I'd greatly appreciate it.
Dec 5, 2019 at 3:34 AM
