Thank you for your reply, new battery fully charged. Checked all fuses and relays have a draw between negative pole and negative cable. The only drop in drain is when I take out the ignition relay fuse. Although the relay clicks and has zero draw across terminals ohms.
Nov 20, 2019 at 5:06 AM
CERTIFIED EXPERT
Are you measuring amps or voltage?
The spec is 50 to 75 milliamps is normal.
Nov 20, 2019 at 6:19 AM
COL JAMES
MEMBER
Thank you for your reply. I think I have found the problem. I am getting an ac reading across the battery when running the engine so I think it must be a bad alternator diode.
