The manufacture had a bulletin out for a possible condition to a draw. Here is the information:
Date: September 17, 2004.
Order No.: P-B-54.21/113
Supersedes:
Group: 54
SUBJECT:
Model 211.026/065/070/076/082/083/265/282/283, up to VIN A530021 or X148458
Model Year 2003 and 2004
Vehicle Can No Longer Be Started / Battery Discharged
If you receive customer reports in the above model vehicles of the vehicle no longer able to be started or the battery being discharged, the Lower Control Panel (LCP) may need to be replaced if the battery has already passed the Midtronics test outlined in S-B-58.00/124a. Follow the procedure below to test and repair.
Note : The vehicle battery may discharge because of high quiescent current drawn from the Lower Control Panel (LCP). A momentary under voltage of approximately 5 Volts results when the pushbutton unit illumination and function lights in the LCP are switched on simultaneously, thus preventing the LCP from switching off completely.
1.Perform quiescent current test as per WIS document AR54.10-P-1030T.
2.If the quiescent current is found to be higher then the stated normal value, by 1.5 to 2.5 A, remove fuse 39 (F34f39) in the Interior Fuse box (F34). Fuse 39 supplies power for the LCP (N72).
3.If the quiescent current value reduces by 1.5 - 2.5 A after step 2 indicated above, then the LCP should be replaced. Remove/install/replace center switch block for LCP as per WIS document AR54.21-P-1263T.
Note : It is not necessary to disconnect the ground line from the battery for this step!
4.If the quiescent current value does not reduce by 1.5 - 2.5 A after step 2 indicated above, then the LCP should not be replaced. Further diagnosis of quiescent current consumption needs to be performed. Follow P-B-54.10190 - BATTERY DIAGNOSTIC TROUBLESHOOTING PROCEDURE for additional guidance.
5.Perform STAR DIAGNOSIS short test and erase fault codes.
Note : Use center switch block for lower control panel control module with new part number according to parts ordering notes. Until publication of the new part number, a note is stored in EPC. The new part will therefore be automatically delivered.
May 8, 2018 at 11:22 PM
