Battery drains out
2003 CHEVROLET TRACKER
132,000 MILES • 1.5L • 6 CYL • 2WD • AUTOMATIC
BOBBYBYRD
Yesterday on the way home, my battery lite came on and off. When i got home it stayed on so i cut car off and started it. It was fine. This morning i tried to start it and the battery was completely dead so i put a new battery in it and started it. I let it idle for about twenty five seconds then revved it up a little. The battery lite came on every time i revved it up and went off when it was idling. I cut car off and checked connections. I tried to start it but the battery was so drained that no lights or alarms would work. No noise at all. What could completely drain a new battery in less than one minute?
Sep 1, 2017 at 3:25 AM
This sounds like it can be one of two problems, either you have a battery cable that is going bad, I would guess positive or the alternator is having a problem.
Here are two guides that will help you do a test and then change the unit out if it is bad:
As far as the battery cable look for bulging at either end which means it has corrosion.
and
https://www.2carpros.com/articles/how-to-replace-an-alternator
Please let us know what happens so it will help others.
Sep 4, 2017 at 2:11 PM
BOBBYBYRD
The battery in my car is about two years and six months old. The battery light came on when i was driving home and kept blinking on and off. When i got home i cut my car off and tried to start it. It started fine. The next morning i tried to start my car but the battery was so drained that no alarms nor lights worked and no noise at all. I put a new battery in it and started it. I let it run about twenty five seconds then revved the motor a little. When i rev the motor the battery light comes on but goes off. when i let the motor idle I cut the car off and checked the connection but when i tried to start it, the new battery was so drained that no lights or alarms worked and it made no noise , not even a click , when i tried to start it. What could have drained the new battery in less than a minute with the car running?
Sep 5, 2017 at 3:13 PM (Merged)
CJ MEDEVAC
  • 11,004 POSTS
Not having hands on there with you.
Check my link out below (cannot hurt).
https://www.2carpros.com/questions/1996-chevrolet-tahoe-wont-start-sounds-dead-battery-jumpbox-get-same-reults
If you can get him a running', let's test the alternator. See this link from the top of our page under "repair guides".
Other things could keep a "good" alternator from charging the battery such as loose connections/fuses/fusible links.
Keep us posted.
The Medic
