The problem isn't in removing the battery cables. The problem is in knowing what to do afterward. For a lot of models, the computer relearns idle speed information by some other strategy, and the driver doesn't even notice that's taking place. As I mentioned, I only have Chrysler's procedure memorized because I have a lot of them. I don't know why they don't publish it in the service manuals. I first learned this at one of their classes I attended. The computer needs to know your foot is off the accelerator pedal, then it takes a reading from the throttle position sensor and puts that in memory. From then on, any time it sees that same voltage, it knows it has to be in control of idle speed. Otherwise it thinks you're controlling engine speed yourself, and it doesn't interfere.
To know your foot is off the accelerator pedal, the computer needs to see high manifold vacuum for seven seconds, with a perfectly stable TPS reading. If the reading bounces around, it knows your foot is on the pedal, so it ignores the relearn. You can get high manifold vacuum in the garage by snapping the throttle open, then releasing it quickly, but that will just last one or two seconds, not the required seven seconds. That's why you have to be at highway speed so you can coast and get that high vacuum for seven seconds. We were even told a lot of battery shops and dealership mechanics are instructed to perform a short test-drive when necessary to do this relearn, for customer satisfaction. I used to just inform people of the need to do that when they leave the shop, but every now and then you get someone who doesn't understand how to drive with one foot on the gas and one on the brake until this is done. It's just easier to do it myself. I kill the battery in my minivan about once a month from running a power inverter. I carry a jump-pack, but each time I have low idle speed until I hit a long off-ramp on my way home. I can see engine speed pick up after that seven seconds as I get to the end of the ramp. That's when the relearn has been completed and the computer is bringing idle speed up to where it should be.
The other thing you might like to be aware of is fuel trim numbers. Every Engine Computer starts off with a factory-programmed set of "look-up" tables. For every possible combination of engine speed, engine load, coolant temperature, intake air temperature, throttle position, throttle direction of change and rate of change, and multiple operating conditions, there is a magic number in those look-up tables that tells the computer exactly how many milliseconds to pulse the injectors open to achieve the proper fuel / air mixture for best performance and fuel mileage, and lowest emissions. The actual mixture is affected by the temperature of the gas in the tank, since that affects how quickly it evaporates and is collected in the charcoal canister, and it's affected by how much unburned gas has snuck past the piston rings and diluted the engine oil. Fumes from both places are drawn off to be burned. That makes the mixture too rich. The computer accounts for that when it sees the switching between "rich" and "lean" about twice per second from the front oxygen sensors. Based on those readings, it fine-tunes the injectors' on-time to readjust the mixture.
That's the long version of how the computer keeps tabs on the fuel metering data. It starts out with those factory default values, then, while you're driving, when it sees the need to inject slightly more or less gas, it modifies the numbers in the look-up tables. Those are called the "short-term fuel-trim", (STFT) numbers. The higher positive they are, the more fuel it's adding right now over the factory values.
Eventually the computer will see it's always making the same corrections for the same set of conditions. At that point, it moves the short-term numbers into the "long-term fuel-trim" (LTFT) numbers. Those are the starting numbers it uses now instead of what was programmed in on the assembly line. There should now be less need to change the short-term numbers while you're driving. All of these numbers can be viewed on a scanner, either as a set of a real lot of data on a table, or simply as the current STFT and LTFT numbers. When you see the short-term numbers are high, the computer is making adjustments right now. When you see the LTFT numbers are high, the computer has made big changes over what was expected to be "normal" by the engineers. If you do a lot of short-trip driving where the engine never gets fully warmed up, there is going to be more unburned gas in the oil. That results in a richer-than-expected mixture when that is pulled out through the PCV system to be burned. That won't happen effectively until you make a nice long trip on the highway with a hot engine and hot oil. You can expect to see high negative fuel trim numbers because the computer is reducing the amount of gas it's injecting to offset what's coming in from the oil or the charcoal canister.
Fuel pressure is also a big player in the fuel / air mixture. Some cars have fuel pressure sensors, but on most models the computer simply knows what the pressure is supposed to be. Spring-loaded mechanical fuel pressure regulators are usually very reliable and accurate, but a weak spring can let gas go through it and back to the tank too easily. That results in low fuel pressure. If the computer doesn't monitor pressure, it will see the resulting lean condition from the oxygen sensors, then make appropriate adjustments in how long it holds the injectors open during each pulse.
Fuel pressure and manifold vacuum are the two forces acting on a molecule of gas as it's ready to leave the injector. Vacuum goes real high during coasting, and that would result in a rich coasting condition and excessive emissions because that vacuum is tugging harder on the gas molecules. To offset that high vacuum, fuel pressure is lowered so the difference between those two forces remains constant. Fuel pressure is most commonly lowered by connecting a vacuum hose to the regulator. Vacuum helps to pull the relief valve open so the fuel can go back to the tank easier, leaving the pressure lower. With higher vacuum and lower pressure during coasting, the net difference is the same, so there's no rich condition.
In this story, a leak in the vacuum hose will look to the regulator like the engine is under hard acceleration. With lower vacuum, the pressure relief valve is harder to push open, so fuel pressure rises. In reality, the engine is just cruising with minimal load, but with the higher fuel pressure, more fuel will flow from the injectors and you'll have an excessively-rich condition. The oxygen sensors can't measure gas, but they will detect the lack of oxygen during the "lean" pulses of exhaust gas. Once again, the computer will adjust for that, but there's a limit to how much it can adjust the short and long-term numbers.
The range of adjustment is designed to handle normal variables and the typical range of those variables. It's when something major happens to affect the fuel / air mixture beyond what the computer can adjust for that performance or emissions problems occur. Emissions problems are detected by the computer and usually include a flashing Check Engine light meaning too much unburned gas is going into the exhaust system where it will burn in the catalytic converter and overheat it. You're supposed to stop the engine as soon as safely possible to avoid expensive damage. Excessively lean conditions also contribute to increased emissions due to incomplete combustion.
The point of this sad story is when you disconnect the battery, the fuel trim numbers are lost. With a properly-running engine, those tables start being rebuilt as soon as you start the engine, and you will rarely notice anything unusual in engine performance.
As a point of interest, Chrysler invented the computer-controlled automatic transmission for '89 models, and they do the same thing with constantly updating shift schedules and clutch overlap to offset the normal wear of the clutch plates. That results in nice crisp like-new shifts throughout the life of the transmission That learning is also lost when the battery is disconnected. It can take up to two miles or a dozen up-shift cycles for that data to be relearned. Until then, the transmission could shift harsh like a dragster, or it could be soft and mushy. By 2000, most other manufacturers had copied the design and now have their own versions. If you notice unusual shifting for the first few miles, don't panic. That will clear up as the data is relearned and updated.
Jul 5, 2019 at 12:25 AM
