battery and emergency brake light on
2008 SUZUKI FORENZA
88,000 MILES • 4 CYL • 2WD • AUTOMATIC
BOSTONSPORTS8
Altenator is less than 2 years old, suzuki bought and installed
brand new battery put in
autozone tested battery and altenator and said both were perfect
spent $90 at suzuki to "find" problem. They told me my brand new battery is not holding a charge
Replaced battery with another new battery
suzuki said it was holding the charge yet the 2 lights come on together and shut off together.
usually its early in the morning or after 8 hours of work. After a little driving, they shut off. but when they are on, my headlights are dim and the heat doesnt work at good..Im not sure if its electrically or not.
Jan 21, 2014 at 10:36 AM
HMAC300
  • 48,601 POSTS
he emergency brake light on may be the abs unit draing on the battery clean the battery to body ground wire see if that helps. try unplugging the e brake and see if that makes a difference if the body ground doesn't work. it cold be the dash is going bad as well.
Jan 22, 2014 at 7:44 AM
BOSTONSPORTS8
I have cleaned the ground cord and really havent seen a difference. Where can I unplug the e-brake? Is there a fuse?
Its a 2008 suzuki forenza.
Jan 22, 2014 at 8:06 AM
HMAC300
  • 48,601 POSTS
I can't find a fuse for the ebrake so it is probably hooked to something else. the dah fuse I is fuse 22 that may do the same thing pull that overnite and see if it makes a difference.
Jan 22, 2014 at 12:24 PM
