I had replaced the clutch etc.; I had finished, and I was about to start the car I had remembered to connect the terminals. The battery is located in the trunk. I remembered that I only disconnected the negative. The positive was still on the battery. I noticed some build up, so I brushed the terminals, and I had the positive off. Made sure none were touching any metal surfaces. I then connected the positive
tightened all up. Just as I am about to connect the negative terminal. It sparks and keeps sparkling and smoking.
Nov 23, 2021 at 12:29 AM
