Battery is about two months old. Car was dead today. Voltage was 0.2 volts Makes me wonder if the battery is totally disconnected. Jumped it from another car for fifteen minutes. Charging voltage was 14 volts. Car then started a-okay Disconnected jumpers and voltage was 12.5 volts. I can't believe the battery charge went from 0.2 to 12.5 in fifteen minutes. Can you? Is there a low voltage cutoff that disconnects the battery if it drops below some safe level?
Jan 16, 2019 at 1:21 PM
