Stability track light, ABS light and traction control light are on
2010 GMC TERRAIN
108,000 MILES • 4 CYL • AUTOMATIC
LUPITA ESPINOZA
I got in my car and started it up and the stability track light, ABS light and traction control light all came on. Ice changed both hub assemblies on the front because there was a popping noise and the lights still did not go off. I do not know what the problem is. Can you help?
Dec 7, 2018 at 11:35 AM
Good afternoon,
The light primary issue is the ABS. It takes stability and trac off line when there is a fault code.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Do you know the code that was checked? If not, a parts store will read it for you for free. Then we can further help you. Guessing is always expensive and most of the time wrong as you see already.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Dec 7, 2018 at 2:42 PM
