Bare wires close to starter
2002 DODGE INTREPID
150,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
JULIE DAVIS2
  • 26 POSTS
While working on this thing I noticed wires wrapped in electric tape? I have no idea why and what they are and what it works. I replaced oxygen sensor upper, crankshaft sensor, camshaft sensor, hope it helped solve my codes and acceleration, but maybe these wires are causing my problems?
Got to finish tomorrow, please offer help.
Have pictures.
Jun 24, 2018 at 7:58 PM
Good morning.
I do need the pictures as well as all the codes you have. Once you have given me that information, I can help guide you on this issue.
Jun 26, 2018 at 6:22 AM
JULIE DAVIS2
  • 26 POSTS
After changing the o2 upward sensor crankshaft, and camshaft my car is coding p0132 and p0871 running worse? I am lost for ideas.
Jun 27, 2018 at 4:04 AM
Okay, what were the codes prior to the repair?
The 132 is for the O2 sensor circuit. There is still a wiring issue at that sensor.
P0132
Item Description
Symptom/DTC P0132
Descriptor
O2 Sensor 1/1 Voltage High
Probable Causes
Oxygen (O2) Sensor
Oxygen Sensor (O2S) Above 3.7 Volts
Oxygen Sensor (O2S) Return Circuit Open
Oxygen Sensor (O2S) Signal Open
Oxygen Sensor (O2S) Signal Shorted to Voltage
Powertrain Control Module (PCM) Return Circuit
Powertrain Control Module (PCM) Signal Circuit
871
P0871
Item Description
Symptom/DTC P0871
Descriptor
Od Pressure Switch Sense Circuit
Probable Causes
Intermittent Wiring and Connectors
Overdrive (OD) Pressure Switch
Overdrive (OD) Pressure Switch Sense Circuit Open
Overdrive (OD) Pressure Switch Sense Circuit Short to Ground
Overdrive (OD) Pressure Switch Sense Circuit Short to Voltage
Powertrain Control Module (PCM) Overdrive Pressure Switch
Related Relay Diagnostic Trouble Codes (DTC's) Present
Transmission Relay Output Circuit Open
Jun 27, 2018 at 4:26 AM
JULIE DAVIS2
  • 26 POSTS
Thank you, checking that now.
Jun 27, 2018 at 6:42 AM
Okay, sounds good.
Keep us updated and if you can, attach some pictures.
Jun 27, 2018 at 6:45 AM
JULIE DAVIS2
  • 26 POSTS
Tip for how I removed a broken crankshaft sensor, after extensive research on web, I found different MSDA charts on chemicals that would break down o-rings, I figured it was rusted and swelled in block as told to me, so after attempting the screw idea and various sprays and it was not budging, I combined a list and sprayed onto the crankshaft and also widdled the outer baked on grease, i took my time and sprayed this on for three days and finally was freed and came right out, success story for sure!
Jun 27, 2018 at 11:05 AM
Good for you. I use a product called Freeze Off. Very good stuff for loosening up seized o-rings.
Jun 27, 2018 at 12:25 PM
