SORRY I don't understand the diagrams...but over the weekend i tested white n blue w/multimeter,it read nothing.. I was so frustrated I went ahead and just replaced air filter, and the bank 2 sensor 1 on my own and turned off the CEL with the OBD2 scanner..so far I have only driven about 40 miles on a full tank on freeway n streets to see if CEL would come back on..it hasnt so far ,,but now when i connect the OBD2 scanner after driving for 15 minutes then have car at IDLE it says..closed loop using 02sensor for fuel mix.
CAN YOU PLEASE PLEASE PLEASE LOOK AT THE INFO AND NUMBERS BELOW AND TELL ME IF YOU SEE ANYTHING BAD OR ANYTHING I NEED TO CHECK, TEST. FIX, OR DO??
engine load- 14.7 throttle position 10.2% MAF 3.2% intake air temp 108f timing advance 15
stft bank2- -0.1% ltft bank2-3.0% stft bank1- 0.1% ltft bank1- -2.3 coolant -194
02s5 wr lambda v- 3.3 02s5 wr lambda ratio- 1. 02s1 wr lambda v- 3.3 02s1 wr lambda ratio- 1.
AFTER SENSOR REPLACED +++ BEFORE SENSOR REPLACED
misfire- complete
fuel system- complete
components-complete
catalyst- complete +++ catalyst- incomplete
heated catalyst- not available evap system- incomplete +++ evap system- complete
secondary air system- not available
A/C refrigerant- not available
o2 sensor-complete +++ 02 sensor - incomplete
02 sensor heater-complete
EGR system- not available
THANK YOU SO MUCH FOR ALL OF YOUR HELP.
also it seems when 1thing goes wrong everything follows suit...
there is a buzzing noise that comes and goes behind component screen heater / A/C / radio..the heater, a/c, everything are "OFF" when it buzzes,..BUT i can also purposely make it buzz by pushing dial to switch the positioning of where i want heat or air to go if it were turned on,..Do you know what that could be??
Sep 12, 2017 at 7:21 PM
