bank 1 sensor 2 o2 sensor
1997 FORD ESCORT
200,000 MILES • 2.0L • 6 CYL • 2WD • AUTOMATIC
JASON1998
I have a p0141 code for my 1997 Ford Escort. I know it is a O2 heater circuit malfunction. I need to know where and how to fix this problem.
Feb 27, 2016 at 12:50 PM
HMAC300
  • 48,601 POSTS
check items in pics first.....
Feb 27, 2016 at 1:00 PM
WRENCHTECH
  • 20,761 POSTS
You have a heater code specifically so most of those things wouldn't apply here. It's not the signal that you have a problem with, just the heater, If it were a power supply fuse it would have knocked pout both sensors so you should be able to eliminate that. That leaves either a bad sensor or related wiring. It's usually the sensor itself with the heater burnt out. This would be the downstream sensor, the one after the converter.
Feb 27, 2016 at 1:44 PM
