Banging noise when shifting gears
2004 JEEP LIBERTY
155,000 MILES • 4WD • MANUAL
TIM COOK2
  • 4 POSTS
First my ignition is broke I have to crank it with a screwdriver. today it started making a banging noise sound like it's under the Jeep it only does it when I am changing gears.
Sep 20, 2019 at 7:59 AM
A banging noise while changing gears on a manual transmission is not related to the ignition. So if a screwdriver is working for you and you don''t want to address that, then the transmission issue is most likely the clutch is beginning to fail.
Here is a guide that explains this in more detail:
https://www.2carpros.com/articles/clutch-symptoms
If this sounds like your issue and we can go deeper. However, more than likely you will need to replace the clutch. If this is the case, I would just go ahead and get a clutch kit that includes all the normal components for a clutch replacement because you only want to go in there once. Let me know what you find. Thanks
Thanks
Sep 20, 2019 at 4:52 PM
TIM COOK2
  • 4 POSTS
Someone today said it was the tension pulley. he pushed me off today to pop the clutch to crank it because I am having trouble cranking it. he looked under the hood and said it needed to be replaced. could that be it? it just doesn't feel like the clutch.
Sep 21, 2019 at 12:09 AM
It could be. Obviously someone looking at it would need to take precedence over someone on the internet. However, based on the way you are describing it, it does sound like a clutch. The clutch may feel fine but that doesn't mean it is fully disengaging when you press it in. This is the most likely cause of a grinding/banging noise only when shifting. However, if the pulley is failed, it could be making noise when you shift because the torque is relieved from the drive train and the engine spins a little more free. Again, I will defer to someone looking at it because I may not be fully understanding the issue. Noises are the hardest thing to try and figure out when you are not looking at the vehicle.
Please let me know what they find because this issue may help others dealing with the same thing and the cause of it would be great info.
Sep 21, 2019 at 7:09 PM
TIM COOK2
  • 4 POSTS
It is an exhaust leak and spark plugs need replaced .
Sep 21, 2019 at 7:18 PM
Okay. Thanks for the info. I didn't see that coming. Thanks for updating us. Please let us know if you need more assistance. Thanks
Sep 21, 2019 at 8:06 PM
TIM COOK2
  • 4 POSTS
Okay, you are welcome. Until next time.
Sep 21, 2019 at 8:08 PM
