Bank 2 sensor location
2014 CADILLAC SRX
57,000 MILES
TITANS05
  • 5 POSTS
Where is the bank 2 sensor located?
Apr 28, 2019 at 4:29 PM
Welcome to 2CarPros.
When you open the hood, bank 2 is the one right up front. The rear is bank one (near the firewall).
Here is a guide to help walk you through the steps with the location of all oxygen sensor in the diagrams below
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Apr 28, 2019 at 7:33 PM
GENERAL.MOTORS
  • 21 POSTS
Hello, when you open the hood, whether 3.6 or v8 north star, its always in left side passenger side thanks
Apr 29, 2019 at 12:50 PM
TITANS05
  • 5 POSTS
Yes, I saw three sensors on the left and i replaced the one in the back but it was not correct. So I was just checking to see which one of the two up front would be correct.
Apr 29, 2019 at 12:54 PM
GENERAL.MOTORS
  • 21 POSTS
Whats the engine size titan
Apr 29, 2019 at 12:55 PM
TITANS05
  • 5 POSTS
V6
Apr 29, 2019 at 1:00 PM
GENERAL.MOTORS
  • 21 POSTS
My opinion, try remove the the oxygen sensors one by one and hook the scanner and see the fault cod's come in scanner, or open live data,
Apr 29, 2019 at 1:05 PM
GENERAL.MOTORS
  • 21 POSTS
You mean oxygen sensors, or cam shaft sensors, because the oxygen sensor is always straight , 2 sensors up stream and down stream in each engine heads pipe, and for cam sensors is numbered a and b
Apr 29, 2019 at 1:07 PM
TITANS05
  • 5 POSTS
camshaft sensor
Apr 29, 2019 at 1:33 PM
TITANS05
  • 5 POSTS
So there are two on the left side up front. I had an error code P0021 Bank 2 camshaft timimg over advanced bank 2
Apr 29, 2019 at 2:43 PM
Welcome back:
Take a look at the attached picture. It shows where the sensors are located. Bank 2 is on the right side of the engine when facing the front of the engine. There is a legend at the bottom of the picture identifying each component
Let me know if this helps. By the way, the pic is specific to your vehicle.
Apr 29, 2019 at 7:09 PM
GENERAL.MOTORS
  • 21 POSTS
If you get this code don't wast you money, because the chains stretched and need new tensioners and chains
Apr 30, 2019 at 11:17 AM
I updated the top response check it out.
May 2, 2019 at 1:04 PM
GENERAL.MOTORS
  • 21 POSTS
Hello, can some one plz tell me about tire pressure sensors on 2005 and up grand cherokee, i am not able to know how its numbered, i have to relearn sensors on scanner, i have no idea in which tire sould i start, its complicated procces, appreciate.
May 2, 2019 at 1:14 PM
Please post your new question here, you must be logged in.
May 2, 2019 at 1:41 PM
