http://fkh161.ca/VW/OilFilterHousing.pdf
Oil Filter Housing, Draining
When installing the oil drain adapter (T40057) , a valve in the oil filter housing is opened. If the oil drain adapter (T40057) is removed, the valve is closed again.
Special tools, testers and auxiliary items required
Oil Drain Adapter (T40057)
Remove the cap - 1 - from the oil filter housing - 2 -.
Hold the hose from the oil drain adapter (T40057) in a container and install the oil drain adapter (T40057) onto the oil filter housing - 2 - until it stops.
Allow the engine oil to drain.
Cheers, Thomas
May 11, 2014 at 2:29 PM
