bad idle
1993 FORD TEMPO
148,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
STEVE3275
Okay, I have a bad idle problem, i tried changing the mass air flow sensor, helped a little, then did a complete tune up, not much change. it seems the colder it is the better it runs, so i thought maybe a air temperature sensor? i just do not know, one thing though, it seems in the summer it runs a lot worse than in the winter, makes me think something to go with the temperature control something. Please help! thanks
Dec 14, 2017 at 5:35 PM
It sounds like you have an engine coolant temperature sensor issue. I would try changing the sensor.
Here is a guide and the location (below) to get the job done:
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Here is the location.
Dec 15, 2017 at 6:50 PM
