Jerry,
I suggest removing the fuel pump so you can blow out the lines. The filter is integral to the sending unit in the fuel tank, so it isn't something you can disconnect under the hood.
Or Very Carefully, you could disconnect the fuel supply hose at the engine, place it in a safe container, and turn the key on and off so the pump empties the tank into the container.
No matter what you do (unless you take everything apart) there is going to be some still present. However, once you get it running, it should clean itself out. It will be very difficult to get it going if you don't clear the fuel line and rail.
Dec 23, 2023 at 9:52 PM
