Possible bad battery
1999 PONTIAC GRAND PRIX
271,534 MILES • 3.8L • V6 • 2WD • AUTOMATIC
JR47
  • 114 POSTS
I went out to start my car this afternoon and nothing, it will not even crank at all, no dash lights come on but my gas, tachometer and speedometer gauges all jump up and down a bit. I drove it yesterday and everything was fine and I did not leave any lights on at all I always check to make sure I did not. I have not checked anything yet but car has had the same battery since I bought it which was six years ago now. I just want your opinion on this.
Aug 26, 2018 at 2:15 PM
STEVE W.
  • 15,113 POSTS
Could be a bad battery but before I condemn it I would verify that you have nice clean tight connections at both ends of the cables. On GM's especially any acid seepage tends to get inside the side mount cables where the connectors are crimped and causes a lot of problems. I have seen more than one cable that looked like new but inside the actual wire was corroded to the point that it was barely hanging on. If you have a local chain parts store or even a WalMart, most will test a battery for free.
Aug 26, 2018 at 2:36 PM
JR47
  • 114 POSTS
Could it be my positive cable it had the most corrosion on the connectors at both ends of it and inside the cable itself at both ends. Battery is fine and I cleaned all other connections which had very little to no corrosion on them and nothing has changed.
Aug 27, 2018 at 8:25 PM
STEVE W.
  • 15,113 POSTS
Could very well be. They love to corrode inside the insulation.
Aug 28, 2018 at 3:28 AM
JR47
  • 114 POSTS
Well, I managed to get the interior lights on and the main dash lights when the ignition is on but the dash lights flicker and dim out after a bit. I have just been changing the connections on the battery cables with some spare ones I found in my garage. It still does not crank it.
Aug 30, 2018 at 6:03 PM
STEVE W.
  • 15,113 POSTS
How did you test the battery? It still sounds like either a bad battery or bad connection.
Aug 30, 2018 at 7:48 PM
