Bad alternator
2000 CHEVROLET IMPALA
115,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
DMILLS27
I have replaced my battery in my car, I was driving down the road then all of a sudden my car started having trouble switching gears. I was thinking that my transmission was going bad. A few blocks down the road I put my car in first gear and I slowly drove it to my house. As soon as I got it to my drive way my car shut off all together. After trying to turn it over I had no power to my car at all. Knowing that my battery was brand new I went in the house to charge it and after about six hours I had tried it again. The car turned over and started for about ten minutes and then everything shut off again. My question is, can a bad alternator cause your transmission to go bad?
May 11, 2018 at 6:33 AM
CARADIODOC
  • 34,306 POSTS
No, but if it is computer controlled, it is the computer that will do weird things, then shut down. All computers become confused when system voltage is low. Once the generator fails, if you had started with a fully-charged battery, you will get about a half hour of driving on just the battery before it runs down. The more high current items you use, like the heater fan, head lights, wipers, etc., the less time you will have before the battery is too weak to keep the electrical system going.
Beginning with 1987 models, GM has had a lot of generator failures. Repeat failures are also very common, but the way to reduce that number of failures is what you already did, that is to replace the battery at the same time unless it is less than about two years old. Due to their design, these generators develop a lot of voltage spikes that can damage the voltage regulator, and interfere with computer sensor signals. The battery absorbs and dampens those spikes, but as they age and the lead flakes off the plates, they lose their ability to do that.
Charging the battery proved everything else is okay since the engine started normally. Use an inexpensive digital voltmeter to measure the battery's voltage when the engine is running. If the charging system is working, it will be between 13.75 and 14.75 volts. If you find that, it only means it is okay to do the rest of the tests, but that requires a professional load tester. In particular, we want to know "full load output current", and "ripple voltage". Those will tell us if all of the generator's internal diodes are okay. If one of the six has failed, you will only be able to get exactly one third of the generator's rated current. A common GM generator is their 90-amp unit. 30 amps from it is not enough to meet the demands of the entire electrical system under all conditions. The battery will have to make up the difference until it slowly runs down.
Here is an article that further explains testing the charging system:
May 11, 2018 at 12:21 PM
