Backup light switch location
2002 CHEVROLET EXPRESS
75,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
LININGER2
I am installing a backup camera and am trying to locate a place under the dash to tie the reverse sensor wire to the wire feeding the backup lights. I could route the wire under the vehicle to the backup lights but would prefer to do it under the dash if possible. I would like a specific location to do that. Thank you
Jan 27, 2020 at 12:34 PM
CARADIODOC
  • 34,306 POSTS
You'll still have to go underneath to the transmission. That's where the switched circuit starts.
Jan 27, 2020 at 4:03 PM
LININGER2
So are you saying that the light green wire that goes to the back up lights goes directly back to the lights and you can’t access that wire under the dash or the hood?
Jan 27, 2020 at 4:40 PM
STEVE W.
  • 15,113 POSTS
It looks like there should be a light green wire that is intended to feed the interior rear view mirror if you have the compass version. The lower part of that harness should be there even without the mirror. Unfortunately the connector and splice numbers are not listed in the locations menu! As such you may have to find it under the van and trace it inside.
Jan 28, 2020 at 11:13 AM
LININGER2
Thank you.
Jan 28, 2020 at 11:26 AM
STEVE W.
  • 15,113 POSTS
You are welcome. Thank you for using 2CarPros.
Jan 28, 2020 at 12:46 PM
