backfires , wont excelerate
1991 MAZDA B2600
375,000 MILES
TRIST
the truck has a bit of a starting problem, the head gasket was replaced recently, the air intake sensor dosnt seem to work, but works when we cut one of the wires on it. the truck starts okay and idles great. the tank had dirty gas so I replaced it, new tank and filter, and now it wont drive properly. I had switched out three filters in the last few months, so it seemed to be a fuel problem, because the truck would run fine , once I replaced the fuel filter. if I try full throttle it cuts out and backfires, nothing, then sometimes it kicks in and I can go around 40mph and then backfire and no throttle. when im in neutral , it seems I can get the revs up a bit, but not much....any ideas..
May 20, 2013 at 11:23 AM
KHLOW2008
  • 41,814 POSTS
You mentioned cutting off a sensor wire, that culd be the cause of the problem. You can't snip off sensor wires as it would only send the control unit into backup mode and this does not rectify the problem, only bypassing the system which would mostly be temporary.
There should be more than one problem from symptoms indicated.
May 20, 2013 at 6:16 PM
