Backfiring blowing the valve cover gasket's out. Combustion fumes in my crank case.
Oct 14, 2017 at 11:17 AM
MHPAUTOS
CERTIFIED EXPERT
more information on when the back fire happens, has any work been done on the ignition system? An inlet back fire often is a cross firing ignition or even a burnt inlet valve. have you done a compression test as yet to prove cylinder integrity?
