truck backfires the PCV sometimes on starting, but
runs perfectly after resetting PCV cap.
Nov 18, 2016 at 10:48 AM
JIS001
CERTIFIED EXPERT
Do you have the correct PCV valve installed? Also have you tried scanning for codes? I would use a more advance scanner for that rather then the quick small ones.
Nov 18, 2016 at 11:01 AM
STEVE BOOK
MEMBER
I have ordered the PCV valve. The only code that shows up is a knock sensor.
Nov 21, 2016 at 7:36 AM
JIS001
CERTIFIED EXPERT
Okay, replace the valve and reset the light and let us know if that fixed the problem or if the code returns.
Nov 21, 2016 at 9:18 AM
STEVE BOOK
MEMBER
replaced the valve, the only code is a knock sensor, an if still backfired.
Nov 25, 2016 at 7:38 AM
CERTIFIED EXPERT
Hey Steve,
I backfire could be caused by an leaking intake valve, here is a guide that will explain all reasons for a backfire.
