My car was backfiring constantly, at all times. I changed the distributor cap, and it was melted across three of the firing points on the cap. I replaced it, and now it is running much better, but still backfires somewhat on deceleration when the engine has been under significant load. I have removed both catalytic converters, and have not yet resealed the exhaust pipes. Prior to disconnecting the battery for this repair, it was giving four trouble codes. They were catalyst efficiency below threshold, random misfire, a code for the EGR Valve, and a code for one of the oxygen sensors(I cannot remember which one). I have owned this car for about a year and a half (It was a junkyard rescue). It already had the random misfire code, as well a noticeable misfire when I got it. The other codes have appeared during the time that I have owned it. I have a picture of the underside of the distributor cap, and can include it if necessary.
Feb 9, 2018 at 3:35 PM
