Backfire
1992 CADILLAC DEVILLE
130,000 MILES • 4.9L • 2WD • AUTOMATIC
TOMC12
  • 4 POSTS
Sometimes engine runs okay. It backfires sometimes, and when it does, it sometimes blows the muffler. After getting through the backfire, the engine runs good, and strong. Sometimes it acts as though it is going to stop, and then it may backfire, and run fine.
Nov 9, 2017 at 10:19 AM
MHPAUTOS
  • 31,937 POSTS
Often a back fire is cross firing ignition leads, or a burnt inlet valve can also cause this. just to be safe get a compression test done and if that is okay, replace the ignition leads, you may see the problem with the leads where they are bunched together. they can become display a white chalky coating on the leads. also, you can often see the sparks jumping, lift the bonnet at night in a dark place and run the engine, get someone to rev the engine up and down. often you can see the fire works under the bonnet, but do not touch as it is very high voltage +40,000 volts.
Here is a guide that may help
https://www.2carpros.com/articles/engine-backfires-while-running
Cheers Mark
Nov 9, 2017 at 4:05 PM
TOMC12
  • 4 POSTS
Today engine ran pretty good until about sixty mph. After that seemed to be running out of power and missing as well as backfire, but not as much as usual.
Nov 10, 2017 at 2:12 PM
MHPAUTOS
  • 31,937 POSTS
i would be checking the ignition leads probably high resistance and cross firing. this is where i would be starting.
Nov 10, 2017 at 8:46 PM
TOMC12
  • 4 POSTS
Here's what we've done on the 4.9 1992 Cadillac engine. Map Sensor, Temp Sensor, Plugs, Plug wires, Throttle Sensor, Oxygen Sensor, Converter, Muffler (Blew it) - Can't read these, but looks like Cap, Buttons. Backfires about 6 miles - until it warms up I guess, and then runs good. made appointment to get new muffler, but afraid to. What now? Thanks, Tom Callahan
Nov 22, 2017 at 2:22 PM
It sounds like you have an ignition component that is cutting in and out which fills the exhaust with raw gas. Does the engine run okay with no misfires or cutting out for a short time?
Nov 24, 2017 at 6:47 PM
TOMC12
  • 4 POSTS
YES IT DOES, It may misfire badly for about 6 miles, and then run good. It may cut out any time during this time however. It is hard to determine when it is going to cut out. It backfires terribly. I made appointment to get a new muffler after the oxygen sensor was installed, but cancelled after a backfire episode.
thanks, Tom Callahan
Nov 25, 2017 at 8:52 AM
I would replace the ignition coil module and pickup coil in the distributor. Here is guide to show you how to do the job.
This is most likely the problem check out the diagrams (Below)
Nov 26, 2017 at 1:53 PM
