Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Cortina
Engine
Symptoms
Idle Rough
back firing and rough idle
1972 FORD CORTINA
1 MILES • 1.6L • 4 CYL • 2WD • MANUAL
COLAN H
MEMBER
1 POST
FOLLOW
brand new engine fitted and fully reco carb also fitted ,genuine weber ,downdraft
Jun 10, 2019 at 9:29 PM
CERTIFIED EXPERT
Welcome to 2CarPros.
Is the back fire through the carburetor or exhaust? Have you checked for vacuum leaks which can cause this? How was the carburetor adjusted?
Here are a couple links you may find helpful:
https://www.2carpros.com/articles/engine-backfires-while-running
Also, are you certain that you have all ignition wires to the correct cylinders?
Jun 11, 2019 at 9:25 PM
