Replaced crankshaft, cam shaft, o2 upstream and atc- transmission sensor and still getting codes of p0016 shows same code of p0016 two times same description of crankshaft/camshaft timing misalignment.
P0700
P0871
Running out of ideas here, checked transmission fluid cold and it is way over any reading, going out now to warm it up and retest hot also checked oil and it was two quarts low? With no oil leaks and not driving at all.
Any help or suggestions would be awesome! Thanks.
Also, AC stopped blowing cold could be a leak or maybe all works in to my problem;
sluggish acceleration at thirty five mph and after sixty mph.
P0700
P0871
Jul 12, 2018 at 9:20 AM
