Fact: Just prior to service, fob battery died, changed w/i 1-2 days; did run out-of-gas and I put in gas leftover in has can. After such, car began to not accelerate.
Service request maybe a tune-up and oil change. Needed: 4 sparks plugs, pack w/ module, 3 qts oil top- off and removed after market alarm system.
Question: Car will not stay start unless negative terminal disconnect, shimmied then a try your luck. Once started, runs good. I failed to alert them that I list the key with the 'chip' in it. Suggested I get a key with a chip cut. Will this correct problem you think?
Nov 27, 2019 at 6:35 PM
