Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Ranger
Electrical
BCM
Codes
B1359
B1359 code?
2003 FORD RANGER
99,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
DARIN EMMETT
MEMBER
FOLLOW
Hello I'm looking for the ignition switch wiring diagram to troubleshoot the b1359 code.
Jul 28, 2025 at 8:44 PM
CERTIFIED EXPERT
Yep, good call, it looks like the switch is bad.
B1359 - Ignition Run/Accessory Circuit Failure
Here is how to change the switch out and the wiring diagrams as requested. Check out the images (below). Let us know if you need anything else.
Jul 29, 2025 at 11:37 AM
